Global Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (6599 entries)
Projection Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (86 entries)
Record Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (57 entries)
Lemma Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (3455 entries)
Section Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (290 entries)
Constructor Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (147 entries)
Abbreviation Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (148 entries)
Inductive Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (53 entries)
Definition Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (1466 entries)
Axiom Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (28 entries)
Module Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (53 entries)
Variable Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (788 entries)
Library Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (28 entries)
I
id [abbreviation, in ssrfun]
idempotent [definition, in ssrfun]
IdentityMorphism [section, in morphisms]
IdentityMorphism.gT [variable, in morphisms]
idfun [definition, in ssrfun]
idm [definition, in morphisms]
idmxE [lemma, in matrix]
idm_morphism [definition, in morphisms]
idm_morphM [lemma, in morphisms]
IdomainType [abbreviation, in ssralg]
idomainType [abbreviation, in ssralg]
idP [lemma, in ssrbool]
idPn [lemma, in ssrbool]
ifE [lemma, in ssrbool]
iffLR [lemma, in ssreflect]
iffLRn [lemma, in ssreflect]
iffP [lemma, in ssrbool]
iffRL [lemma, in ssreflect]
iffRLn [lemma, in ssreflect]
ifnE [lemma, in ssrnat]
ifnz [definition, in prime]
ifnzP [lemma, in prime]
IfnzPos [constructor, in prime]
IfnzZero [constructor, in prime]
ifnz_spec [inductive, in prime]
ifn_expr [definition, in ssrnat]
ifP [lemma, in ssrbool]
IfSpecFalse [constructor, in ssrbool]
IfSpecTrue [constructor, in ssrbool]
if_arg [lemma, in ssrbool]
if_expr [definition, in ssrbool]
if_neg [lemma, in ssrbool]
if_same [lemma, in ssrbool]
if_spec [inductive, in ssrbool]
iinv [definition, in fintype]
iinv_f [lemma, in fintype]
iinv_proof [lemma, in fintype]
Image [section, in fintype]
image [definition, in fintype]
imageP [lemma, in fintype]
Image.Def [section, in fintype]
Image.Def.A [variable, in fintype]
Image.Def.injf [variable, in fintype]
Image.f [variable, in fintype]
Image.T [variable, in fintype]
Image.T' [variable, in fintype]
image_codom [lemma, in fintype]
image_f [lemma, in fintype]
image_iinv [lemma, in fintype]
image_pre [lemma, in fintype]
image_pred0 [lemma, in fintype]
implybE [lemma, in ssrbool]
implybF [lemma, in ssrbool]
implybN [lemma, in ssrbool]
implybT [lemma, in ssrbool]
implyFb [lemma, in ssrbool]
implyP [lemma, in ssrbool]
implyTb [lemma, in ssrbool]
imset [abbreviation, in finset]
Imset [module, in finset]
ImsetCurry [section, in finset]
ImsetCurry.aT1 [variable, in finset]
ImsetCurry.aT2 [variable, in finset]
ImsetCurry.Curry [section, in finset]
ImsetCurry.Curry.A1 [variable, in finset]
ImsetCurry.Curry.A2 [variable, in finset]
ImsetCurry.Curry.D1 [variable, in finset]
ImsetCurry.Curry.D2 [variable, in finset]
ImsetCurry.f [variable, in finset]
ImsetCurry.rT [variable, in finset]
imsetI [lemma, in finset]
imsetP [lemma, in finset]
imsetS [lemma, in finset]
ImsetSig [module, in finset]
ImsetSig.imset [axiom, in finset]
ImsetSig.imsetE [axiom, in finset]
ImsetSig.imset2 [axiom, in finset]
ImsetSig.imset2E [axiom, in finset]
imsetU [lemma, in finset]
imsetU1 [lemma, in finset]
Imset.imset [definition, in finset]
Imset.imsetE [lemma, in finset]
Imset.imset2 [definition, in finset]
Imset.imset2E [lemma, in finset]
imset0 [lemma, in finset]
imset2 [abbreviation, in finset]
imset2P [lemma, in finset]
imset2S [lemma, in finset]
imset2Sl [lemma, in finset]
Imset2spec [constructor, in finset]
imset2Sr [lemma, in finset]
imset2Ul [lemma, in finset]
imset2Ur [lemma, in finset]
imset2_def [abbreviation, in finset]
imset2_pair [lemma, in finset]
imset2_set1l [lemma, in finset]
imset2_set1r [lemma, in finset]
imset2_spec [inductive, in finset]
imset2_unlock [definition, in finset]
imset_autE [lemma, in automorphism]
imset_card [lemma, in finset]
imset_comp [lemma, in finset]
imset_coset [lemma, in normal]
imset_def [abbreviation, in finset]
imset_proper [lemma, in finset]
imset_set1 [lemma, in finset]
imset_unlock [definition, in finset]
inA_bij [lemma, in ssrbool]
incr_nth [definition, in seq]
index [definition, in seq]
indexg [definition, in groups]
indexgg [lemma, in groups]
indexgI [lemma, in groups]
indexgS [lemma, in groups]
indexg1 [lemma, in groups]
indexg_gt0 [lemma, in groups]
indexJg [lemma, in groups]
indexSg [lemma, in groups]
index1g [lemma, in groups]
index_cat [lemma, in seq]
index_cosetpre [lemma, in normal]
index_enum [definition, in bigops]
index_enum_ord [lemma, in fintype]
index_head [lemma, in seq]
index_injm [lemma, in normal]
index_iota [definition, in bigops]
index_last [lemma, in seq]
index_map [lemma, in seq]
index_mem [lemma, in seq]
index_morphim [lemma, in normal]
index_morphim_ker [lemma, in normal]
index_morphpre [lemma, in normal]
index_quotient [lemma, in normal]
index_quotient_eq [lemma, in normal]
index_quotient_ker [lemma, in normal]
index_size [lemma, in seq]
index_uniq [lemma, in seq]
inE [definition, in finset]
inE [definition, in ssrbool]
inE [definition, in seq]
InheritedClasses [section, in groups]
InheritedClasses.T [variable, in groups]
Injections [section, in ssrfun]
InjectionsTheory [section, in ssrfun]
InjectionsTheory.A [variable, in ssrfun]
InjectionsTheory.B [variable, in ssrfun]
InjectionsTheory.C [variable, in ssrfun]
InjectionsTheory.f [variable, in ssrfun]
InjectionsTheory.g [variable, in ssrfun]
InjectionsTheory.h [variable, in ssrfun]
Injections.aT [variable, in ssrfun]
Injections.f [variable, in ssrfun]
Injections.rT [variable, in ssrfun]
injective [definition, in ssrfun]
Injectiveb [section, in fintype]
injectiveb [definition, in fintype]
Injectiveb.aT [variable, in fintype]
Injectiveb.f [variable, in fintype]
Injectiveb.rT [variable, in fintype]
injectiveP [lemma, in fintype]
injectivePn [lemma, in fintype]
InjEqMixin [definition, in eqtype]
injF_bij [lemma, in fintype]
injF_codom [lemma, in fintype]
injmI [lemma, in morphisms]
injmK [lemma, in morphisms]
injmP [lemma, in morphisms]
injmSK [lemma, in morphisms]
injm1 [lemma, in morphisms]
injm_abelian [lemma, in morphisms]
injm_autm [lemma, in automorphism]
injm_cent [lemma, in morphisms]
injm_cent1 [lemma, in morphisms]
injm_comp [lemma, in morphisms]
injm_conj [lemma, in automorphism]
injm_cyclem [lemma, in cyclic]
injm_cyclic [lemma, in cyclic]
injm_factm [lemma, in morphisms]
injm_factmP [lemma, in morphisms]
injm_generator [lemma, in cyclic]
injm_idm [lemma, in morphisms]
injm_invm [lemma, in morphisms]
injm_norm [lemma, in morphisms]
injm_quotm [lemma, in normal]
injm_restrm [lemma, in morphisms]
injm_sgval [lemma, in morphisms]
injm_subcent [lemma, in morphisms]
injm_subcent1 [lemma, in morphisms]
injm_subg [lemma, in morphisms]
injm_subnorm [lemma, in morphisms]
injm_Zpm [lemma, in cyclic]
injm_Zp_unitm [lemma, in cyclic]
inj_can_eq [lemma, in ssrfun]
inj_can_sym [lemma, in ssrfun]
inj_comp [lemma, in ssrfun]
inj_eq [lemma, in eqtype]
inj_eqAxiom [lemma, in eqtype]
inj_id [lemma, in ssrfun]
inj_map [lemma, in seq]
inj_tperm [lemma, in perm]
innew [definition, in eqtype]
innew_val [lemma, in eqtype]
inord [definition, in fintype]
inordK [lemma, in fintype]
inord_val [lemma, in fintype]
inPhantom [definition, in ssrbool]
insigd [definition, in eqtype]
insT [definition, in seq]
insub [definition, in eqtype]
insubd [definition, in eqtype]
insubdK [lemma, in eqtype]
insubF [lemma, in eqtype]
insubK [lemma, in eqtype]
insubN [lemma, in eqtype]
InsubNone [constructor, in eqtype]
insubP [lemma, in eqtype]
InsubSome [constructor, in eqtype]
insubT [lemma, in eqtype]
insub_eq [definition, in eqtype]
insub_eqE [lemma, in eqtype]
insub_spec [inductive, in eqtype]
IntegralDomain [module, in ssralg]
introF [lemma, in ssrbool]
introFn [lemma, in ssrbool]
introN [lemma, in ssrbool]
introNf [lemma, in ssrbool]
introNTF [lemma, in ssrbool]
introP [lemma, in ssrbool]
introT [lemma, in ssrbool]
introTF [lemma, in ssrbool]
introTFn [lemma, in ssrbool]
introTn [lemma, in ssrbool]
intro_adjunction [lemma, in connect]
intro_closed [lemma, in connect]
intro_unit_mx [lemma, in matrix]
invariant [definition, in eqtype]
invariant_comp [lemma, in eqtype]
invariant_inj [lemma, in eqtype]
invCg [lemma, in groups]
invDg [lemma, in groups]
InverseMorphism [section, in morphisms]
InverseMorphism.aT [variable, in morphisms]
InverseMorphism.f [variable, in morphisms]
InverseMorphism.G [variable, in morphisms]
InverseMorphism.injf [variable, in morphisms]
InverseMorphism.rT [variable, in morphisms]
invF [definition, in fintype]
invF_f [lemma, in fintype]
invg [definition, in groups]
invGid [lemma, in groups]
invgK [lemma, in groups]
invg1 [lemma, in groups]
invg_comm [lemma, in groups]
invg_expg [lemma, in groups]
invg_inj [lemma, in groups]
invg_lcoset [lemma, in groups]
invg_rcoset [lemma, in groups]
invg_set1 [lemma, in groups]
invIg [lemma, in groups]
invm [definition, in morphisms]
invmE [lemma, in morphisms]
invMG [lemma, in groups]
invMg [lemma, in groups]
invmK [lemma, in morphisms]
invmx [definition, in matrix]
invmx_out [lemma, in matrix]
invm_dom [lemma, in morphisms]
invm_morphism [definition, in morphisms]
invm_subker [lemma, in morphisms]
Involutions [section, in ssrfun]
Involutions.A [variable, in ssrfun]
Involutions.f [variable, in ssrfun]
Involutions.Hf [variable, in ssrfun]
involutive [definition, in ssrfun]
InvQuotientSpec [constructor, in normal]
invSg [lemma, in groups]
invUg [lemma, in groups]
inv_bij [lemma, in ssrfun]
inv_eq [lemma, in eqtype]
inv_inj [lemma, in ssrfun]
inv_quotientN [lemma, in normal]
inv_quotientS [lemma, in normal]
inv_quotient_spec [inductive, in normal]
inv_subG [lemma, in groups]
inW_bij [lemma, in ssrbool]
inZp [definition, in zmodp]
in1A [lemma, in ssrbool]
in1W [lemma, in ssrbool]
in2A [lemma, in ssrbool]
in2W [lemma, in ssrbool]
in3A [lemma, in ssrbool]
in3W [lemma, in ssrbool]
in_cons [lemma, in seq]
in_group [definition, in groups]
in_iinv_f [lemma, in fintype]
in_mem [definition, in ssrbool]
in_nil [lemma, in seq]
in_set [lemma, in finset]
in_setC [lemma, in finset]
in_setC1 [lemma, in finset]
in_setD [lemma, in finset]
in_setD1 [lemma, in finset]
in_setI [lemma, in finset]
in_setT [lemma, in finset]
in_setU [lemma, in finset]
in_setU1 [lemma, in finset]
in_setX [lemma, in finset]
in_set0 [lemma, in finset]
in_set1 [lemma, in finset]
in_set2 [lemma, in finset]
in_simpl [lemma, in ssrbool]
iota [definition, in seq]
iota_add [lemma, in seq]
iota_addl [lemma, in seq]
iota_tuple [definition, in tuple]
iota_tupleP [lemma, in tuple]
iota_uniq [lemma, in seq]
irreflexive [definition, in ssrbool]
isgroupP [lemma, in groups]
isMem [definition, in ssrbool]
IsoBoolEquiv [section, in morphisms]
IsoBoolEquiv.G [variable, in morphisms]
IsoBoolEquiv.gT [variable, in morphisms]
IsoBoolEquiv.H [variable, in morphisms]
IsoBoolEquiv.hT [variable, in morphisms]
IsoBoolEquiv.K [variable, in morphisms]
IsoBoolEquiv.kT [variable, in morphisms]
IsoCyclic [section, in cyclic]
IsoCyclic.gT [variable, in cyclic]
IsoCyclic.rT [variable, in cyclic]
isog [definition, in morphisms]
isogP [lemma, in morphisms]
isog_abelian [lemma, in morphisms]
isog_card [lemma, in morphisms]
isog_cyclic [lemma, in cyclic]
isog_cyclic_card [lemma, in cyclic]
isog_refl [lemma, in morphisms]
isog_subg [lemma, in morphisms]
isog_sym [lemma, in morphisms]
isog_symr [lemma, in morphisms]
isog_trans [lemma, in morphisms]
isog_transl [lemma, in morphisms]
isog_transr [lemma, in morphisms]
isog_triv [lemma, in morphisms]
isom [definition, in morphisms]
Isomorphisms [section, in morphisms]
Isomorphisms.G [variable, in morphisms]
Isomorphisms.gT [variable, in morphisms]
Isomorphisms.H [variable, in morphisms]
Isomorphisms.hT [variable, in morphisms]
Isomorphisms.K [variable, in morphisms]
Isomorphisms.kT [variable, in morphisms]
isomP [lemma, in morphisms]
isom_card [lemma, in morphisms]
isom_isog [lemma, in morphisms]
isom_sgval [lemma, in morphisms]
isom_subg [lemma, in morphisms]
isSome [definition, in ssrbool]
isSome_insub [lemma, in eqtype]
is_inl [definition, in ssrbool]
is_inleft [definition, in ssrbool]
is_left [definition, in ssrbool]
is_perm_mx [definition, in matrix]
is_perm_mxMl [lemma, in matrix]
is_perm_mxMr [lemma, in matrix]
is_perm_mxP [lemma, in matrix]
is_perm_mxV [lemma, in matrix]
is_perm_mx1 [lemma, in matrix]
is_true [definition, in ssrbool]
is_true_locked_true [lemma, in ssrbool]
is_true_true [lemma, in ssrbool]
iter [definition, in ssrnat]
Iteration [section, in ssrnat]
Iteration.T [variable, in ssrnat]
iteri [definition, in ssrnat]
iteriS [lemma, in ssrnat]
iterop [definition, in ssrnat]
iteropS [lemma, in ssrnat]
iterS [lemma, in ssrnat]
iterSr [lemma, in ssrnat]
iter_add [lemma, in ssrnat]
iter_findex [lemma, in connect]
iter_finv [lemma, in connect]
iter_order [lemma, in connect]
