Global Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (6599 entries)
Projection Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (86 entries)
Record Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (57 entries)
Lemma Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (3455 entries)
Section Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (290 entries)
Constructor Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (147 entries)
Abbreviation Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (148 entries)
Inductive Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (53 entries)
Definition Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (1466 entries)
Axiom Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (28 entries)
Module Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (53 entries)
Variable Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (788 entries)
Library Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (28 entries)
O
oapp [abbreviation, in ssrfun]
obind [abbreviation, in ssrfun]
ocancel [definition, in ssrfun]
odd [definition, in ssrnat]
oddb [lemma, in ssrnat]
odd_add [lemma, in ssrnat]
odd_double [lemma, in ssrnat]
odd_double_half [lemma, in ssrnat]
odd_exp [lemma, in ssrnat]
odd_lift_perm [lemma, in matrix]
odd_mod [lemma, in div]
odd_mul [lemma, in ssrnat]
odd_mul_tperm [lemma, in perm]
odd_opp [lemma, in ssrnat]
odd_perm [definition, in perm]
odd_permJ [lemma, in perm]
odd_permM [lemma, in perm]
odd_permV [lemma, in perm]
odd_perm1 [lemma, in perm]
odd_perm_prod [lemma, in perm]
odd_sub [lemma, in ssrnat]
odd_tperm [lemma, in perm]
odd_2'nat [lemma, in prime]
odflt [abbreviation, in ssrfun]
ohead [definition, in seq]
omap [abbreviation, in ssrfun]
onA_bij [lemma, in ssrbool]
oneg [definition, in groups]
one_group [definition, in groups]
onPhantom [definition, in ssrbool]
onW_bij [lemma, in ssrbool]
on1A [lemma, in ssrbool]
on1lA [lemma, in ssrbool]
on1lW [lemma, in ssrbool]
on1W [lemma, in ssrbool]
on2A [lemma, in ssrbool]
on2W [lemma, in ssrbool]
on_can_inj [lemma, in ssrbool]
on_card_preimset [lemma, in finset]
op [definition, in finset]
OperationProperties [section, in ssrfun]
OperationProperties.add [variable, in ssrfun]
OperationProperties.inv [variable, in ssrfun]
OperationProperties.mul [variable, in ssrfun]
OperationProperties.one [variable, in ssrfun]
OperationProperties.T [variable, in ssrfun]
OperationProperties.zero [variable, in ssrfun]
oppmx [definition, in matrix]
opp_poly [definition, in poly]
OpsTheory [section, in fintype]
OpsTheory.EnumPick [section, in fintype]
OpsTheory.EnumPick.P [variable, in fintype]
OpsTheory.T [variable, in fintype]
Option [module, in ssrfun]
OptionEqType [section, in eqtype]
OptionEqType.T [variable, in eqtype]
OptionFinType [section, in fintype]
OptionFinType.T [variable, in fintype]
Option.apply [definition, in ssrfun]
Option.bind [definition, in ssrfun]
Option.default [definition, in ssrfun]
Option.map [definition, in ssrfun]
option_choiceMixin [definition, in choice]
option_choiceType [definition, in choice]
option_countMixin [definition, in choice]
option_countType [definition, in choice]
option_enum [definition, in fintype]
option_enumP [lemma, in fintype]
option_eqMixin [definition, in eqtype]
option_eqType [definition, in eqtype]
option_finMixin [definition, in fintype]
option_finType [definition, in fintype]
opt_eq [definition, in eqtype]
opt_eqP [lemma, in eqtype]
orbA [lemma, in ssrbool]
orbAC [lemma, in ssrbool]
orbb [lemma, in ssrbool]
orbC [lemma, in ssrbool]
orbCA [lemma, in ssrbool]
orbF [lemma, in ssrbool]
Orbit [section, in connect]
orbit [definition, in connect]
Orbit.f [variable, in connect]
Orbit.Hf [variable, in connect]
Orbit.Loop [section, in connect]
Orbit.Loop.Hp [variable, in connect]
Orbit.Loop.Hx [variable, in connect]
Orbit.Loop.p [variable, in connect]
Orbit.Loop.Up [variable, in connect]
Orbit.Loop.x [variable, in connect]
Orbit.T [variable, in connect]
orbit_rot_cycle [lemma, in connect]
orbit_uniq [lemma, in connect]
orbK [lemma, in ssrbool]
orbN [lemma, in ssrbool]
orbT [lemma, in ssrbool]
orb_addoid [definition, in bigops]
orb_andl [lemma, in ssrbool]
orb_andr [lemma, in ssrbool]
orb_comoid [definition, in bigops]
orb_monoid [definition, in bigops]
orb_muloid [definition, in bigops]
order [definition, in groups]
order [definition, in connect]
orderJ [lemma, in groups]
orderM [lemma, in cyclic]
orderSpred [lemma, in connect]
orderV [lemma, in groups]
orderXdiv [lemma, in cyclic]
orderXdvd [lemma, in cyclic]
orderXgcd [lemma, in cyclic]
order1 [lemma, in groups]
order_cycle [lemma, in connect]
order_div_card [lemma, in connect]
order_dvdG [lemma, in cyclic]
order_dvdn [lemma, in cyclic]
order_eq1 [lemma, in cyclic]
order_finv [lemma, in connect]
order_gt0 [lemma, in groups]
order_inf [lemma, in cyclic]
order_inj_cyclic [lemma, in cyclic]
order_path_min [lemma, in paths]
order_pos_nat [definition, in groups]
order_set [definition, in connect]
order_set_finv [lemma, in connect]
Ordinal [constructor, in fintype]
ordinal [inductive, in fintype]
OrdinalEnum [section, in fintype]
OrdinalEnum.n [variable, in fintype]
OrdinalPos [section, in fintype]
OrdinalPos.n [variable, in fintype]
OrdinalSub [section, in fintype]
OrdinalSub.n [variable, in fintype]
ordinal_choiceMixin [definition, in fintype]
ordinal_choiceType [definition, in fintype]
ordinal_countMixin [definition, in fintype]
ordinal_countType [definition, in fintype]
ordinal_eqMixin [definition, in fintype]
ordinal_eqType [definition, in fintype]
ordinal_finMixin [definition, in fintype]
ordinal_finType [definition, in fintype]
ordinal_subCountType [definition, in fintype]
ordinal_subFinType [definition, in fintype]
ordinal_subType [definition, in fintype]
ord0 [definition, in fintype]
ord1 [lemma, in zmodp]
ord_enum [definition, in fintype]
ord_enum_uniq [lemma, in fintype]
ord_inj [lemma, in fintype]
ord_max [definition, in fintype]
ord_maxP [lemma, in fintype]
ord_opp [definition, in fintype]
ord_oppK [lemma, in fintype]
ord_sub [definition, in fintype]
ord_subP [lemma, in fintype]
ord_tuple [definition, in tuple]
orFb [lemma, in ssrbool]
orKb [lemma, in ssrbool]
orNb [lemma, in ssrbool]
orP [lemma, in ssrbool]
orTb [lemma, in ssrbool]
or3 [inductive, in ssrbool]
or3P [lemma, in ssrbool]
Or31 [constructor, in ssrbool]
Or32 [constructor, in ssrbool]
Or33 [constructor, in ssrbool]
or4 [inductive, in ssrbool]
or4P [lemma, in ssrbool]
Or41 [constructor, in ssrbool]
Or42 [constructor, in ssrbool]
Or43 [constructor, in ssrbool]
Or44 [constructor, in ssrbool]
OtherEncodings [section, in choice]
OtherEncodings.T [variable, in choice]
out_Aut [lemma, in automorphism]
out_perm [lemma, in perm]
