Global Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (6599 entries)
Projection Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (86 entries)
Record Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (57 entries)
Lemma Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (3455 entries)
Section Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (290 entries)
Constructor Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (147 entries)
Abbreviation Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (148 entries)
Inductive Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (53 entries)
Definition Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (1466 entries)
Axiom Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (28 entries)
Module Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (53 entries)
Variable Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (788 entries)
Library Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ (28 entries)
S
sameP [lemma, in ssrbool]
same_connect [lemma, in connect]
same_connect_r [lemma, in connect]
same_connect_rev [lemma, in connect]
same_count1 [definition, in seq]
same_cover_at [lemma, in finset]
same_fconnect1 [lemma, in connect]
same_fconnect1_r [lemma, in connect]
same_fconnect_finv [lemma, in connect]
scalar_mx [definition, in matrix]
scalar_mx0 [lemma, in matrix]
scalar_mx_add [lemma, in matrix]
scalar_mx_comm [lemma, in matrix]
scalar_mx_mul [lemma, in matrix]
scalar_mx_opp [lemma, in matrix]
scalemx [definition, in matrix]
scalemxA [lemma, in matrix]
scalemxAl [lemma, in matrix]
scalemxAr [lemma, in matrix]
scalemxN [lemma, in matrix]
scalemx0 [lemma, in matrix]
scalemx_add [lemma, in matrix]
scalemx_addl [lemma, in matrix]
scalemx_addr [lemma, in matrix]
scalemx_block [lemma, in matrix]
scalemx_paste [lemma, in matrix]
scalemx_subl [lemma, in matrix]
scalemx_subr [lemma, in matrix]
scaleNmx [lemma, in matrix]
scale0mx [lemma, in matrix]
scale1mx [lemma, in matrix]
scalp [definition, in poly]
scalp_id [lemma, in poly]
scalp_spec [lemma, in poly]
Scan [section, in seq]
scanl [definition, in seq]
scanlK [lemma, in seq]
scanl_tuple [definition, in tuple]
scanl_tupleP [lemma, in tuple]
Scan.f [variable, in seq]
Scan.g [variable, in seq]
Scan.T1 [variable, in seq]
Scan.T2 [variable, in seq]
Scan.x1 [variable, in seq]
Scan.x2 [variable, in seq]
SecondIsomorphism [section, in normal]
SecondIsomorphism.gT [variable, in normal]
SecondIsomorphism.H [variable, in normal]
SecondIsomorphism.K [variable, in normal]
SecondIsomorphism.nKH [variable, in normal]
second_isog [lemma, in normal]
second_isom [lemma, in normal]
self_inverse [definition, in ssrfun]
seq [inductive, in seq]
seq [library]
SeqFinType [section, in fintype]
SeqFinType.s [variable, in fintype]
SeqFinType.T [variable, in fintype]
seqn [definition, in seq]
seqn_rec [definition, in seq]
seqn_type [definition, in seq]
SeqSub [constructor, in fintype]
SeqTuple [section, in tuple]
SeqTuple.n [variable, in tuple]
SeqTuple.rT [variable, in tuple]
SeqTuple.T [variable, in tuple]
Sequences [section, in seq]
Sequences.n0 [variable, in seq]
Sequences.SeqFind [section, in seq]
Sequences.SeqFind.a [variable, in seq]
Sequences.T [variable, in seq]
Sequences.x0 [variable, in seq]
Seq2 [module, in choice]
seq2_of [definition, in choice]
seq2_ofK [lemma, in choice]
seq_choiceMixin [definition, in choice]
seq_choiceType [definition, in choice]
seq_countMixin [definition, in choice]
seq_countType [definition, in choice]
seq_eqMixin [definition, in seq]
seq_eqType [definition, in seq]
seq_factor [lemma, in poly]
seq_mul_polyX [lemma, in poly]
seq_of_opt [definition, in choice]
seq_of_optK [lemma, in choice]
seq_polyXn [lemma, in poly]
seq_poly0 [lemma, in poly]
seq_predType [definition, in seq]
seq_sub [record, in fintype]
seq_sub_choiceMixin [definition, in fintype]
seq_sub_choiceType [definition, in fintype]
seq_sub_countMixin [definition, in fintype]
seq_sub_countType [definition, in fintype]
seq_sub_enum [definition, in fintype]
seq_sub_eqMixin [definition, in fintype]
seq_sub_eqType [definition, in fintype]
seq_sub_finMixin [definition, in fintype]
seq_sub_finType [definition, in fintype]
seq_sub_pickle [definition, in fintype]
seq_sub_pickleK [lemma, in fintype]
seq_sub_subCountType [definition, in fintype]
seq_sub_subFinType [definition, in fintype]
seq_sub_subType [definition, in fintype]
seq_sub_unpickle [definition, in fintype]
setC [definition, in finset]
setCD [lemma, in finset]
setCI [lemma, in finset]
setCK [lemma, in finset]
setCP [lemma, in finset]
setCS [lemma, in finset]
setCT [lemma, in finset]
setCU [lemma, in finset]
setC0 [lemma, in finset]
setC11 [lemma, in finset]
setC_bigcap [lemma, in finset]
setC_bigcup [lemma, in finset]
setC_inj [lemma, in finset]
setD [definition, in finset]
setDDl [lemma, in finset]
setDDr [lemma, in finset]
setDE [lemma, in finset]
SetDef [module, in finset]
SetDefSig [module, in finset]
SetDefSig.finset [axiom, in finset]
SetDefSig.finsetE [axiom, in finset]
SetDefSig.pred_of_set [axiom, in finset]
SetDefSig.pred_of_setE [axiom, in finset]
SetDef.finset [definition, in finset]
SetDef.finsetE [lemma, in finset]
SetDef.pred_of_set [definition, in finset]
SetDef.pred_of_setE [lemma, in finset]
setDeq0 [lemma, in finset]
setDidPl [lemma, in finset]
setDIl [lemma, in finset]
setDIr [lemma, in finset]
setDP [lemma, in finset]
setDS [lemma, in finset]
setDSS [lemma, in finset]
setDT [lemma, in finset]
setDUl [lemma, in finset]
setDUr [lemma, in finset]
setDv [lemma, in finset]
setD0 [lemma, in finset]
setD1K [lemma, in finset]
setD1P [lemma, in finset]
setD11 [lemma, in finset]
setI [definition, in finset]
setIA [lemma, in finset]
setIAC [lemma, in finset]
setIC [lemma, in finset]
setICA [lemma, in finset]
setICr [lemma, in finset]
setIdP [lemma, in finset]
setIid [lemma, in finset]
setIidPl [lemma, in finset]
setIidPr [lemma, in finset]
setIIl [lemma, in finset]
setIIr [lemma, in finset]
setIK [lemma, in finset]
setIP [lemma, in finset]
setIS [lemma, in finset]
setISS [lemma, in finset]
setIT [lemma, in finset]
setIUl [lemma, in finset]
setIUr [lemma, in finset]
setI0 [lemma, in finset]
setI_addoid [definition, in finset]
setI_comoid [definition, in finset]
setI_group [definition, in groups]
setI_monoid [definition, in finset]
setI_muloid [definition, in finset]
setKI [lemma, in finset]
setKU [lemma, in finset]
SetMulDef [section, in groups]
SetMulDef.gT [variable, in groups]
setOps [section, in finset]
setOpsAlgebra [section, in finset]
setOpsAlgebra.T [variable, in finset]
setOpsDefs [section, in finset]
setOpsDefs.T [variable, in finset]
setOps.T [variable, in finset]
setP [lemma, in finset]
setSD [lemma, in finset]
setSI [lemma, in finset]
setSU [lemma, in finset]
setT [definition, in finset]
setTD [lemma, in finset]
setTI [lemma, in finset]
setTU [lemma, in finset]
SetType [section, in finset]
SetType.T [variable, in finset]
setT_group [definition, in groups]
setU [definition, in finset]
setUA [lemma, in finset]
setUAC [lemma, in finset]
setUC [lemma, in finset]
setUCA [lemma, in finset]
setUCr [lemma, in finset]
setUid [lemma, in finset]
setUidPl [lemma, in finset]
setUidPr [lemma, in finset]
setUIl [lemma, in finset]
setUIr [lemma, in finset]
setUK [lemma, in finset]
setUP [lemma, in finset]
setUS [lemma, in finset]
setUSS [lemma, in finset]
setUT [lemma, in finset]
setUUl [lemma, in finset]
setUUr [lemma, in finset]
setU0 [lemma, in finset]
setU1K [lemma, in finset]
setU1P [lemma, in finset]
setU1r [lemma, in finset]
setU11 [lemma, in finset]
setU_addoid [definition, in finset]
setU_comoid [definition, in finset]
setU_monoid [definition, in finset]
setU_muloid [definition, in finset]
setX [definition, in finset]
setXP [lemma, in finset]
setXS [lemma, in finset]
set0 [definition, in finset]
set0D [lemma, in finset]
set0I [lemma, in finset]
set0Pn [lemma, in finset]
set0U [lemma, in finset]
set1 [definition, in finset]
set1gE [lemma, in groups]
set1gP [lemma, in groups]
set1P [lemma, in finset]
set1Ul [lemma, in finset]
set1Ur [lemma, in finset]
set11 [lemma, in finset]
set1_group [definition, in groups]
set2P [lemma, in finset]
set21 [lemma, in finset]
set22 [lemma, in finset]
set_choiceMixin [definition, in finset]
set_choiceType [definition, in finset]
set_cons [lemma, in finset]
set_countMixin [definition, in finset]
set_countType [definition, in finset]
set_eqMixin [definition, in finset]
set_eqType [definition, in finset]
set_finMixin [definition, in finset]
set_finType [definition, in finset]
set_invg [definition, in groups]
set_invgK [lemma, in groups]
set_invgM [lemma, in groups]
set_mulg [definition, in groups]
set_mulgA [lemma, in groups]
set_mul1g [lemma, in groups]
set_nth [definition, in seq]
set_nth_default [lemma, in seq]
set_nth_nil [lemma, in seq]
set_of [definition, in finset]
set_of_choiceType [definition, in finset]
set_of_coset [projection, in normal]
set_of_countType [definition, in finset]
set_of_eqType [definition, in finset]
set_of_finType [definition, in finset]
set_of_subCountType [definition, in finset]
set_of_subFinType [definition, in finset]
set_of_subType [definition, in finset]
set_partition_big [lemma, in finset]
set_predType [definition, in finset]
set_set_nth [lemma, in seq]
set_subCountType [definition, in finset]
set_subFinType [definition, in finset]
set_subType [definition, in finset]
set_type [inductive, in finset]
set_0Vmem [lemma, in finset]
sfT [definition, in fintype]
sgval [definition, in groups]
sgvalEdom [lemma, in morphisms]
sgvalK [lemma, in groups]
sgvalM [lemma, in groups]
sgvalmK [lemma, in morphisms]
sgval_morphism [definition, in morphisms]
sgval_sub [lemma, in morphisms]
shape [definition, in seq]
shorten [definition, in paths]
shortenP [lemma, in paths]
ShortenSpec [constructor, in paths]
shorten_spec [inductive, in paths]
sieve [definition, in seq]
Sieve [section, in seq]
Sieve.n0 [variable, in seq]
Sieve.T [variable, in seq]
sieve0 [lemma, in seq]
sieve1 [lemma, in seq]
sieve_cat [lemma, in seq]
sieve_cons [lemma, in seq]
sieve_false [lemma, in seq]
sieve_rot [lemma, in seq]
sieve_true [lemma, in seq]
sieve_uniq [lemma, in seq]
SigEqType [section, in eqtype]
SigEqType.P [variable, in eqtype]
SigEqType.T [variable, in eqtype]
SigProj [section, in eqtype]
SigProj.P [variable, in eqtype]
SigProj.Q [variable, in eqtype]
SigProj.T [variable, in eqtype]
sig_choiceMixin [definition, in choice]
sig_choiceType [definition, in choice]
sig_countMixin [definition, in choice]
sig_countType [definition, in choice]
sig_eqMixin [definition, in eqtype]
sig_eqType [definition, in eqtype]
sig_finMixin [definition, in fintype]
sig_finType [definition, in fintype]
sig_subCountType [definition, in choice]
sig_subFinType [definition, in fintype]
sig_subType [definition, in eqtype]
simp [abbreviation, in matrix]
simp [abbreviation, in poly]
SimplFun [constructor, in ssrfun]
SimplFun [section, in ssrfun]
SimplFunDelta [definition, in ssrfun]
SimplFun.aT [variable, in ssrfun]
SimplFun.rT [variable, in ssrfun]
SimplPred [definition, in ssrbool]
simplPredType [definition, in ssrbool]
SimplRel [definition, in ssrbool]
simpl_fun [inductive, in ssrfun]
simpl_mem [section, in ssrbool]
simpl_mem.pT [variable, in ssrbool]
simpl_mem.T [variable, in ssrbool]
simpl_pred [definition, in ssrbool]
simpl_predE [lemma, in ssrbool]
simpl_rel [definition, in ssrbool]
size [definition, in seq]
size0nil [lemma, in seq]
size1_polyC [lemma, in poly]
size1_zip [lemma, in seq]
size2_zip [lemma, in seq]
size_add [lemma, in poly]
size_addl [lemma, in poly]
size_behead [lemma, in seq]
size_belast [lemma, in seq]
size_cat [lemma, in seq]
size_drop [lemma, in seq]
size_dvdp [lemma, in poly]
size_enum_ord [lemma, in fintype]
size_eqp [lemma, in poly]
size_eq0 [lemma, in seq]
size_exp [lemma, in poly]
size_flatten [lemma, in seq]
size_incr_nth [lemma, in seq]
size_iota [lemma, in seq]
size_map [lemma, in seq]
size_merge [lemma, in paths]
size_mkseq [lemma, in seq]
size_monic_mul [lemma, in poly]
size_mul [lemma, in poly]
size_mul_id [lemma, in poly]
size_mul_monic [lemma, in poly]
size_ncons [lemma, in seq]
size_nseq [lemma, in seq]
size_opp [lemma, in poly]
size_orbit [lemma, in connect]
size_pairmap [lemma, in seq]
size_pmap [lemma, in seq]
size_pmap_sub [lemma, in seq]
size_Poly [lemma, in poly]
size_poly [lemma, in poly]
size_polyC [lemma, in poly]
size_polyC_mul [lemma, in poly]
size_polyX [lemma, in poly]
size_polyXn [lemma, in poly]
size_poly0 [lemma, in poly]
size_poly1 [lemma, in poly]
size_poly_cons [lemma, in poly]
size_poly_eq [lemma, in poly]
size_poly_eq0 [lemma, in poly]
size_proper_mul [lemma, in poly]
size_rcons [lemma, in seq]
size_rev [lemma, in seq]
size_rot [lemma, in seq]
size_rotr [lemma, in seq]
size_scanl [lemma, in seq]
size_set_nth [lemma, in seq]
size_sieve [lemma, in seq]
size_sort [lemma, in paths]
size_sum [lemma, in poly]
size_take [lemma, in seq]
size_takel [lemma, in seq]
size_traject [lemma, in paths]
size_tuple [lemma, in tuple]
size_undup [lemma, in seq]
Slicing [section, in matrix]
Slicing.Block [section, in matrix]
Slicing.Block.CutBlock [section, in matrix]
Slicing.Block.CutBlock.A [variable, in matrix]
Slicing.Block.m1 [variable, in matrix]
Slicing.Block.m2 [variable, in matrix]
Slicing.Block.n1 [variable, in matrix]
Slicing.Block.n2 [variable, in matrix]
Slicing.Block.PasteBlock [section, in matrix]
Slicing.Block.PasteBlock.All [variable, in matrix]
Slicing.Block.PasteBlock.Alr [variable, in matrix]
Slicing.Block.PasteBlock.Aul [variable, in matrix]
Slicing.Block.PasteBlock.Aur [variable, in matrix]
Slicing.CutPaste [section, in matrix]
Slicing.CutPaste.m [variable, in matrix]
Slicing.CutPaste.n1 [variable, in matrix]
Slicing.CutPaste.n2 [variable, in matrix]
Slicing.R [variable, in matrix]
Slicing.TrBlock [section, in matrix]
Slicing.TrBlock.m1 [variable, in matrix]
Slicing.TrBlock.m2 [variable, in matrix]
Slicing.TrBlock.n1 [variable, in matrix]
Slicing.TrBlock.n2 [variable, in matrix]
Slicing.TrBlock.TrCut [section, in matrix]
Slicing.TrBlock.TrCut.A [variable, in matrix]
SmulProp [section, in groups]
SmulProp.gT [variable, in groups]
some [abbreviation, in ssrfun]
SomeChoiceTypes [section, in choice]
SomeChoiceTypes.P [variable, in choice]
SomeChoiceTypes.T [variable, in choice]
sort [definition, in paths]
sorted [definition, in paths]
sorted_divisors [lemma, in prime]
sorted_divisors_ltn [lemma, in prime]
sorted_filter [lemma, in paths]
sorted_iota [lemma, in paths]
sorted_ltn_iota [lemma, in paths]
sorted_ltn_uniq_leq [lemma, in paths]
sorted_merge [lemma, in paths]
sorted_primes [lemma, in prime]
sorted_sort [lemma, in paths]
sorted_uniq [lemma, in paths]
SortSeq [section, in paths]
SortSeq.leT [variable, in paths]
SortSeq.leT_total [variable, in paths]
SortSeq.T [variable, in paths]
SortSeq.Transitive [section, in paths]
SortSeq.Transitive.leT_tr [variable, in paths]
sort_of_simpl_pred [definition, in ssrbool]
sort_uniq [lemma, in paths]
split [definition, in fintype]
Split [constructor, in paths]
split [inductive, in paths]
SplitHi [constructor, in fintype]
splitK [lemma, in fintype]
Splitl [constructor, in paths]
splitl [inductive, in paths]
SplitLo [constructor, in fintype]
splitP [lemma, in paths]
splitP [lemma, in fintype]
splitPl [lemma, in paths]
splitPr [lemma, in paths]
splitP2r [lemma, in paths]
Splitr [constructor, in paths]
splitr [inductive, in paths]
split1 [lemma, in matrix]
split2r [inductive, in paths]
Split2r [constructor, in paths]
split_spec [inductive, in fintype]
split_subproof [lemma, in fintype]
sqrn_add [lemma, in ssrnat]
sqrn_add_sub [lemma, in ssrnat]
sqrn_gt0 [lemma, in ssrnat]
sqrn_inj [lemma, in ssrnat]
sqrn_sub [lemma, in ssrnat]
ssetI [definition, in finset]
ssralg [library]
ssrbool [library]
ssreflect [library]
ssrfun [library]
ssrnat [library]
SsrSyntax [module, in ssreflect]
ssr_have [definition, in ssreflect]
ssr_suff [definition, in ssreflect]
ssr_wlog [definition, in ssreflect]
ssval [projection, in fintype]
ssvalP [projection, in fintype]
sT [abbreviation, in groups]
sT [abbreviation, in finset]
strict_adjunction [lemma, in connect]
Sub [projection, in eqtype]
subBaseFinGroupType [definition, in groups]
subCountType [record, in choice]
SubCountType [constructor, in choice]
SubCountType [section, in choice]
SubCountType.P [variable, in choice]
SubCountType.T [variable, in choice]
SubCountType_for [definition, in choice]
subCount_sort [projection, in choice]
subDset [lemma, in finset]
subEproper [lemma, in finset]
SubEqMixin [definition, in eqtype]
SubEqType [section, in eqtype]
SubEqType.P [variable, in eqtype]
SubEqType.sT [variable, in eqtype]
SubEqType.T [variable, in eqtype]
subFinGroupMixin [definition, in groups]
subFinGroupType [definition, in groups]
SubFinMixin [definition, in fintype]
SubFinMixin_for [definition, in fintype]
subFinType [record, in fintype]
SubFinType [section, in fintype]
SubFinType [constructor, in fintype]
SubFinType.P [variable, in fintype]
SubFinType.T [variable, in fintype]
subFinType_finType [definition, in fintype]
subFinType_for [definition, in fintype]
subFin_sort [projection, in fintype]
subg [definition, in groups]
Subg [constructor, in groups]
subgEdom [lemma, in morphisms]
subgK [lemma, in groups]
subgM [lemma, in groups]
subgmK [lemma, in morphisms]
subgP [lemma, in groups]
subG1 [lemma, in groups]
subg_choiceMixin [definition, in groups]
subg_choiceType [definition, in groups]
subg_countMixin [definition, in groups]
subg_countType [definition, in groups]
subg_default [lemma, in groups]
subg_eqMixin [definition, in groups]
subg_eqType [definition, in groups]
subg_finMixin [definition, in groups]
subg_finType [definition, in groups]
subg_inj [lemma, in groups]
subg_inv [definition, in groups]
subg_invP [lemma, in groups]
subg_morphism [definition, in morphisms]
subg_mul [definition, in groups]
subg_mulP [lemma, in groups]
subg_of [inductive, in groups]
subg_one [definition, in groups]
subg_oneP [lemma, in groups]
subg_subCountType [definition, in groups]
subg_subFinType [definition, in groups]
subg_subType [definition, in groups]
subIset [lemma, in finset]
SubK [lemma, in eqtype]
subKn [lemma, in ssrnat]
SubMorphism [section, in morphisms]
SubMorphism.G [variable, in morphisms]
SubMorphism.gT [variable, in morphisms]
submxK [lemma, in matrix]
subn [definition, in ssrnat]
subnE [lemma, in ssrnat]
subnK [lemma, in ssrnat]
subnKC [lemma, in ssrnat]
subnn [lemma, in ssrnat]
subn0 [lemma, in ssrnat]
subn1 [lemma, in ssrnat]
subn_add2l [lemma, in ssrnat]
subn_add2r [lemma, in ssrnat]
subn_eq0 [lemma, in ssrnat]
subn_gt0 [lemma, in ssrnat]
subn_if_gt [lemma, in ssrnat]
subn_rec [definition, in ssrnat]
subn_sqr [lemma, in ssrnat]
subn_sub [lemma, in ssrnat]
subn_subA [lemma, in ssrnat]
subon1 [lemma, in ssrbool]
subon1l [lemma, in ssrbool]
subon2 [lemma, in ssrbool]
subon_bij [lemma, in ssrbool]
SubP [lemma, in eqtype]
subpred [definition, in ssrbool]
subrel [definition, in ssrbool]
subrelUl [lemma, in ssrbool]
subrelUr [lemma, in ssrbool]
subsetD [lemma, in finset]
SubsetDef [module, in fintype]
SubsetDefSig [module, in fintype]
SubsetDefSig.subset [axiom, in fintype]
SubsetDefSig.subsetEdef [axiom, in fintype]
SubsetDef.subset [definition, in fintype]
SubsetDef.subsetEdef [definition, in fintype]
subsetDl [lemma, in finset]
subsetDr [lemma, in finset]
subsetD1 [lemma, in finset]
subsetE [lemma, in fintype]
subsetI [lemma, in finset]
subsetIl [lemma, in finset]
subsetIr [lemma, in finset]
subsetP [lemma, in fintype]
subsetPn [lemma, in fintype]
subsets_disjoint [lemma, in finset]
subsetT [lemma, in finset]
subsetU [lemma, in finset]
subsetUl [lemma, in finset]
subsetUr [lemma, in finset]
subset0 [lemma, in finset]
subset1 [lemma, in finset]
subset_all [lemma, in fintype]
subset_cardP [lemma, in fintype]
subset_closure [lemma, in connect]
subset_def [abbreviation, in fintype]
subset_dfs [lemma, in connect]
subset_disjoint [lemma, in fintype]
subset_eqP [lemma, in fintype]
subset_gen [lemma, in groups]
subset_leqif_card [lemma, in fintype]
subset_leq_card [lemma, in fintype]
subset_predT [lemma, in fintype]
subset_pred1 [lemma, in fintype]
subset_trans [lemma, in fintype]
subset_type [abbreviation, in fintype]
subset_unlock [definition, in fintype]
subSnn [lemma, in ssrnat]
SubSpec [constructor, in eqtype]
subSS [lemma, in ssrnat]
subTset [lemma, in finset]
SubType [constructor, in eqtype]
subType [record, in eqtype]
SubType [section, in eqtype]
SubType.P [variable, in eqtype]
SubType.sT [variable, in eqtype]
SubType.T [variable, in eqtype]
subUset [lemma, in finset]
subxx [lemma, in fintype]
subxx_hint [lemma, in fintype]
sub0n [lemma, in ssrnat]
sub0set [lemma, in finset]
sub1G [lemma, in groups]
sub1set [lemma, in finset]
sub_choiceMixin [definition, in choice]
sub_choiceType [definition, in choice]
sub_conjg [lemma, in groups]
sub_conjgV [lemma, in groups]
sub_cosetpre [lemma, in normal]
sub_cosetpre_quo [lemma, in normal]
sub_countMixin [definition, in choice]
sub_countType [definition, in choice]
sub_enum_uniq [lemma, in fintype]
sub_eqMixin [definition, in eqtype]
sub_eqType [definition, in eqtype]
sub_gen [lemma, in groups]
sub_in1 [lemma, in ssrbool]
sub_in11 [lemma, in ssrbool]
sub_in111 [lemma, in ssrbool]
sub_in12 [lemma, in ssrbool]
sub_in2 [lemma, in ssrbool]
sub_in21 [lemma, in ssrbool]
sub_in3 [lemma, in ssrbool]
sub_in_bij [lemma, in ssrbool]
sub_in_partn [lemma, in prime]
sub_in_pnat [lemma, in prime]
sub_isog [lemma, in morphisms]
sub_isom [lemma, in morphisms]
sub_mem [definition, in ssrbool]
sub_morphim_pre [lemma, in morphisms]
sub_morphpre_im [lemma, in morphisms]
sub_morphpre_injm [lemma, in morphisms]
sub_ordK [lemma, in fintype]
sub_path [lemma, in paths]
sub_proper_trans [lemma, in fintype]
sub_quotient_pre [lemma, in normal]
sub_sort [projection, in eqtype]
Sub_spec [inductive, in eqtype]
sub_sub_minn [lemma, in ssrnat]
succn [abbreviation, in ssrnat]
succnK [lemma, in ssrnat]
succn_inj [lemma, in ssrnat]
SumEqType [section, in eqtype]
SumEqType.T1 [variable, in eqtype]
SumEqType.T2 [variable, in eqtype]
SumFinType [section, in fintype]
SumFinType.T1 [variable, in fintype]
SumFinType.T2 [variable, in fintype]
summand [definition, in choice]
summxE [lemma, in matrix]
sumn [definition, in seq]
sumn_cat [lemma, in seq]
sumn_nseq [lemma, in seq]
SumTag [section, in choice]
SumTag.sT [variable, in choice]
SumTag.sT_sort [variable, in choice]
SumTag.T1 [variable, in choice]
SumTag.T2 [variable, in choice]
sum1dep_card [lemma, in finset]
sum1_card [lemma, in bigops]
sum_choiceMixin [definition, in choice]
sum_choiceType [definition, in choice]
sum_countMixin [definition, in choice]
sum_countType [definition, in choice]
sum_enum [definition, in fintype]
sum_enum_uniq [lemma, in fintype]
sum_eq [definition, in eqtype]
sum_eqE [lemma, in eqtype]
sum_eqMixin [definition, in eqtype]
sum_eqP [lemma, in eqtype]
sum_eqType [definition, in eqtype]
sum_finMixin [definition, in fintype]
sum_finType [definition, in fintype]
sum_nat_const [lemma, in bigops]
sum_nat_const_nat [lemma, in bigops]
sum_nat_dep_const [lemma, in finset]
sum_ncycle_phi [lemma, in cyclic]
sum_of_tag [definition, in choice]
sum_of_tagK [lemma, in choice]
sum_phi_dvd [lemma, in cyclic]
support [definition, in finfun]
sval [abbreviation, in eqtype]
svalP [lemma, in eqtype]
symmetric [definition, in ssrbool]
symmetric_from_pre [lemma, in ssrbool]
s2val [definition, in eqtype]
s2valP [lemma, in eqtype]
s2valP' [lemma, in eqtype]
S_pos_nat [definition, in ssrnat]
