Global Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (14626 entries)
Projection Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (165 entries)
Record Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (112 entries)
Lemma Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (7292 entries)
Section Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (761 entries)
Constructor Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (250 entries)
Abbreviation Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (390 entries)
Inductive Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (84 entries)
Definition Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (3144 entries)
Module Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (126 entries)
Axiom Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (28 entries)
Variable Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (2221 entries)
Library Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (53 entries)
O
oapp [abbreviation, in ssrfun]
obind [abbreviation, in ssrfun]
ocancel [definition, in ssrfun]
odd [definition, in ssrnat]
oddb [lemma, in ssrnat]
oddSg [lemma, in pgroup]
odd_perm [definition, in perm]
odd_mul [lemma, in ssrnat]
odd_permM [lemma, in perm]
odd_opp [lemma, in ssrnat]
odd_double_half [lemma, in ssrnat]
odd_pgroup_odd [lemma, in pgroup]
odd_sub [lemma, in ssrnat]
odd_add [lemma, in ssrnat]
odd_mul_tperm [lemma, in perm]
odd_tperm [lemma, in perm]
odd_double [lemma, in ssrnat]
odd_permV [lemma, in perm]
odd_exp [lemma, in ssrnat]
odd_not_extremal2 [lemma, in extremal]
odd_pgroup_rank1_cyclic [lemma, in extremal]
odd_2'nat [lemma, in prime]
odd_mod [lemma, in div]
odd_perm_prod [lemma, in perm]
odd_lift_perm [lemma, in perm]
odd_permJ [lemma, in perm]
odd_perm1 [lemma, in perm]
odflt [abbreviation, in ssrfun]
ohead [definition, in seq]
Ohm [definition, in abelian]
OhmE [lemma, in abelian]
OhmEabelian [lemma, in abelian]
OhmJ [lemma, in abelian]
OhmPredP [lemma, in abelian]
OhmProps [section, in abelian]
OhmProps.char [section, in abelian]
OhmProps.char.D [variable, in abelian]
OhmProps.char.G [variable, in abelian]
OhmProps.char.gT [variable, in abelian]
OhmProps.char.n [variable, in abelian]
OhmProps.char.rT [variable, in abelian]
OhmProps.Generic [section, in abelian]
OhmProps.Generic.gT [variable, in abelian]
OhmProps.Generic.n [variable, in abelian]
OhmProps.gT [variable, in abelian]
OhmS [lemma, in abelian]
Ohm_mgFun [definition, in abelian]
Ohm_gFun [definition, in abelian]
Ohm_igFun [definition, in abelian]
Ohm_group [definition, in abelian]
Ohm_char [lemma, in abelian]
Ohm_p_cycle [lemma, in abelian]
Ohm_cont [lemma, in abelian]
Ohm_Mho_homocyclic [lemma, in abelian]
Ohm_id [lemma, in abelian]
Ohm_sub [lemma, in abelian]
Ohm_normal [lemma, in abelian]
Ohm_dprod [lemma, in abelian]
Ohm_leq [lemma, in abelian]
Ohm0 [lemma, in abelian]
Ohm1 [lemma, in abelian]
Ohm1Eexponent [lemma, in abelian]
Ohm1Eprime [lemma, in abelian]
Ohm1_cent_max [lemma, in abelian]
Ohm1_cyclic_pgroup_prime [lemma, in abelian]
Ohm1_id [lemma, in abelian]
Ohm1_cent_max_normal_abelem [lemma, in maximal]
Ohm1_homocyclicP [lemma, in abelian]
Ohm1_stab_Ohm1_SCN_series [lemma, in maximal]
Ohm1_extraspecial_odd [lemma, in extraspecial]
Ohm1_eq1 [lemma, in abelian]
Ohm1_abelem [lemma, in abelian]
omap [abbreviation, in ssrfun]
oneg [definition, in fingroup]
one_group [definition, in fingroup]
onPhantom [definition, in ssrbool]
onT_bij [lemma, in ssrbool]
onW_bij [lemma, in ssrbool]
on_can_inj [lemma, in ssrbool]
on_card_preimset [lemma, in finset]
on1lT [lemma, in ssrbool]
on1lW [lemma, in ssrbool]
on1T [lemma, in ssrbool]
on1W [lemma, in ssrbool]
on2T [lemma, in ssrbool]
on2W [lemma, in ssrbool]
opair_of_injK [lemma, in choice]
opair_of_inj [definition, in choice]
OperationProperties [section, in ssrfun]
OperationProperties.R [variable, in ssrfun]
OperationProperties.S [variable, in ssrfun]
OperationProperties.SopSisS [section, in ssrfun]
OperationProperties.SopSisT [section, in ssrfun]
OperationProperties.SopTisR [section, in ssrfun]
OperationProperties.SopTisS [section, in ssrfun]
OperationProperties.SopTisT [section, in ssrfun]
OperationProperties.T [variable, in ssrfun]
oppmx [definition, in matrix]
opp_poly [definition, in poly]
opp_lapp [definition, in vector]
opp_row_mx [lemma, in matrix]
opp_col_mx [lemma, in matrix]
opp_block_mx [lemma, in matrix]
opp_lappE [lemma, in vector]
OpsTheory [section, in fintype]
OpsTheory.EnumPick [section, in fintype]
OpsTheory.EnumPick.P [variable, in fintype]
OpsTheory.T [variable, in fintype]
Option [module, in ssrfun]
OptionEqType [section, in eqtype]
OptionEqType.T [variable, in eqtype]
OptionFinType [section, in fintype]
OptionFinType.T [variable, in fintype]
option_finMixin [definition, in fintype]
option_countMixin [definition, in choice]
option_finType [definition, in fintype]
option_enumP [lemma, in fintype]
option_eqType [definition, in eqtype]
option_eqMixin [definition, in eqtype]
option_countType [definition, in choice]
option_choiceType [definition, in choice]
option_enum [definition, in fintype]
option_choiceMixin [definition, in choice]
Option.apply [definition, in ssrfun]
Option.bind [definition, in ssrfun]
Option.default [definition, in ssrfun]
Option.map [definition, in ssrfun]
opt_eqP [lemma, in eqtype]
opt_eq [definition, in eqtype]
orbA [lemma, in ssrbool]
orbAC [lemma, in ssrbool]
orbb [lemma, in ssrbool]
orbb_idr [lemma, in ssrbool]
orbC [lemma, in ssrbool]
orbCA [lemma, in ssrbool]
orbF [lemma, in ssrbool]
Orbit [section, in fingraph]
orbit [definition, in action]
orbit [definition, in fingraph]
orbitE [lemma, in action]
orbitJ [lemma, in action]
orbitJs [lemma, in action]
orbitP [lemma, in action]
orbitR [lemma, in action]
orbitRs [lemma, in action]
orbit_conjsg_in [lemma, in action]
orbit_inv_in [lemma, in action]
orbit_in_trans [lemma, in action]
orbit_in_sym [lemma, in action]
orbit_trans [lemma, in action]
orbit_transr [lemma, in action]
orbit_in_transr [lemma, in action]
orbit_refl [lemma, in action]
orbit_rcoset [lemma, in action]
orbit_rel [abbreviation, in action]
orbit_morphim_actperm [lemma, in action]
orbit_uniq [lemma, in fingraph]
orbit_lcoset_in [lemma, in action]
orbit_stabilizer [lemma, in action]
orbit_eq_mem [lemma, in action]
orbit_inv [lemma, in action]
orbit_rot_cycle [lemma, in fingraph]
orbit_sym [lemma, in action]
orbit_transl [lemma, in action]
orbit_rcoset_in [lemma, in action]
orbit_in_transl [lemma, in action]
orbit_lcoset [lemma, in action]
orbit_conjsg [lemma, in action]
Orbit.f [variable, in fingraph]
Orbit.Hf [variable, in fingraph]
Orbit.Loop [section, in fingraph]
Orbit.Loop.Hp [variable, in fingraph]
Orbit.Loop.Hx [variable, in fingraph]
Orbit.Loop.p [variable, in fingraph]
Orbit.Loop.Up [variable, in fingraph]
Orbit.Loop.x [variable, in fingraph]
Orbit.T [variable, in fingraph]
orbit1P [lemma, in action]
orbK [lemma, in ssrbool]
orbN [lemma, in ssrbool]
orbT [lemma, in ssrbool]
orb_id2l [lemma, in ssrbool]
orb_id2r [lemma, in ssrbool]
orb_andr [lemma, in ssrbool]
orb_addoid [definition, in bigop]
orb_muloid [definition, in bigop]
orb_comoid [definition, in bigop]
orb_monoid [definition, in bigop]
orb_andl [lemma, in ssrbool]
orb_idl [lemma, in ssrbool]
order [definition, in fingraph]
order [definition, in fingroup]
orderE [lemma, in fingroup]
orderJ [lemma, in fingroup]
orderM [lemma, in cyclic]
orderSpred [lemma, in fingraph]
orderV [lemma, in fingroup]
orderXdiv [lemma, in cyclic]
orderXdvd [lemma, in cyclic]
orderXexp [lemma, in cyclic]
orderXgcd [lemma, in cyclic]
orderXpfactor [lemma, in cyclic]
orderXpnat [lemma, in cyclic]
orderXprime [lemma, in cyclic]
order_inf [lemma, in cyclic]
order_gt0 [lemma, in fingroup]
order_set_finv [lemma, in fingraph]
order_set [definition, in fingraph]
order_gt1 [lemma, in fingroup]
order_inj_cyclic [lemma, in cyclic]
order_Zp1 [lemma, in zmodp]
order_div_card [lemma, in fingraph]
order_finv [lemma, in fingraph]
order_injm [lemma, in morphism]
order_path_min [lemma, in path]
order_cycle [lemma, in fingraph]
order_eq1 [lemma, in fingroup]
order_dvdn [lemma, in cyclic]
order_dvdG [lemma, in cyclic]
order_constt [lemma, in pgroup]
order1 [lemma, in fingroup]
ordinal [inductive, in fintype]
Ordinal [constructor, in fintype]
OrdinalEnum [section, in fintype]
OrdinalEnum.n [variable, in fintype]
OrdinalPos [section, in fintype]
OrdinalPos.n' [variable, in fintype]
OrdinalSub [section, in fintype]
OrdinalSub.n [variable, in fintype]
ordinal_choiceMixin [definition, in fintype]
ordinal_finMixin [definition, in fintype]
ordinal_subFinType [definition, in fintype]
ordinal_finType [definition, in fintype]
ordinal_subCountType [definition, in fintype]
ordinal_countType [definition, in fintype]
ordinal_choiceType [definition, in fintype]
ordinal_eqType [definition, in fintype]
ordinal_subType [definition, in fintype]
ordinal_eqMixin [definition, in fintype]
ordinal_countMixin [definition, in fintype]
ord_enum_uniq [lemma, in fintype]
ord_enum [definition, in fintype]
ord_tuple [definition, in tuple]
ord_max [definition, in fintype]
ord_inj [lemma, in fintype]
ord0 [definition, in fintype]
ord1 [lemma, in zmodp]
orFb [lemma, in ssrbool]
orKb [lemma, in ssrbool]
orNb [lemma, in ssrbool]
orP [lemma, in ssrbool]
orTb [lemma, in ssrbool]
or3 [inductive, in ssrbool]
or3P [lemma, in ssrbool]
Or31 [constructor, in ssrbool]
Or32 [constructor, in ssrbool]
Or33 [constructor, in ssrbool]
or4 [inductive, in ssrbool]
or4P [lemma, in ssrbool]
Or41 [constructor, in ssrbool]
Or42 [constructor, in ssrbool]
Or43 [constructor, in ssrbool]
Or44 [constructor, in ssrbool]
OtherEncodings [section, in choice]
OtherEncodings.T [variable, in choice]
OtherEncodings.T1 [variable, in choice]
OtherEncodings.T2 [variable, in choice]
out_Aut [lemma, in automorphism]
out_perm [lemma, in perm]
oZ [definition, in maximal]
oZp [definition, in mxabelem]
