Global Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (14626 entries)
Projection Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (165 entries)
Record Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (112 entries)
Lemma Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (7292 entries)
Section Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (761 entries)
Constructor Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (250 entries)
Abbreviation Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (390 entries)
Inductive Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (84 entries)
Definition Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (3144 entries)
Module Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (126 entries)
Axiom Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (28 entries)
Variable Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (2221 entries)
Library Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (53 entries)
T
tag [definition, in eqtype]
TagEqType [section, in eqtype]
TagEqType.I [variable, in eqtype]
TagEqType.T_ [variable, in eqtype]
TagFinType [section, in fintype]
TagFinType.I [variable, in fintype]
TagFinType.T_ [variable, in fintype]
tagged [definition, in eqtype]
Tagged [definition, in eqtype]
TaggedAs [section, in eqtype]
TaggedAs.I [variable, in eqtype]
TaggedAs.T_ [variable, in eqtype]
tagged_asE [lemma, in eqtype]
tagged_as [definition, in eqtype]
TagSeq [section, in choice]
TagSeq.I [variable, in choice]
TagSeq.T_ [variable, in choice]
tag_count_of_seq [definition, in choice]
tag_choiceMixin [definition, in choice]
tag_of_pair [definition, in choice]
tag_finType [definition, in fintype]
tag_eqP [lemma, in eqtype]
tag_eqE [lemma, in eqtype]
tag_of_pairK [lemma, in choice]
tag_eqType [definition, in eqtype]
tag_eqMixin [definition, in eqtype]
tag_finMixin [definition, in fintype]
tag_eq [definition, in eqtype]
tag_countMixin [definition, in choice]
tag_countType [definition, in choice]
tag_choiceType [definition, in choice]
tag_enum [definition, in fintype]
tag_enumP [lemma, in fintype]
take [definition, in seq]
takel_cat [lemma, in seq]
take_tuple [definition, in tuple]
take_cons [lemma, in seq]
take_tupleP [lemma, in tuple]
take_size_cat [lemma, in seq]
take_cat [lemma, in seq]
take_nth [lemma, in seq]
take_size [lemma, in seq]
take_oversize [lemma, in seq]
take0 [lemma, in seq]
term [abbreviation, in mxrepresentation]
textbook_triangular_sum [lemma, in binomial]
tG [abbreviation, in mxrepresentation]
thead [definition, in tuple]
theadE [lemma, in tuple]
TheCanonical [module, in ssreflect]
TheCanonical.get [definition, in ssreflect]
TheCanonical.get_by [definition, in ssreflect]
TheCanonical.put [inductive, in ssreflect]
TheCanonical.Put [constructor, in ssreflect]
Theory [module, in ssralg]
Theory [module, in finalg]
Theory [section, in perm]
Theory [module, in bigop]
Theory.T [variable, in perm]
thinmx0 [lemma, in matrix]
ThirdIsomorphism [section, in quotient]
ThirdIsomorphism.G [variable, in quotient]
ThirdIsomorphism.gT [variable, in quotient]
ThirdIsomorphism.H [variable, in quotient]
ThirdIsomorphism.K [variable, in quotient]
ThirdIsomorphism.sHK [variable, in quotient]
ThirdIsomorphism.snHG [variable, in quotient]
ThirdIsomorphism.snKG [variable, in quotient]
third_isog [lemma, in quotient]
third_isom [lemma, in quotient]
Thompson_critical [lemma, in maximal]
three_subgroup [lemma, in commutator]
TIconjP [lemma, in frobenius]
TIconj_SN_P [lemma, in frobenius]
TIp1ElemP [lemma, in abelian]
TIsum [definition, in vector]
TIsum [definition, in mxalgebra]
TI_cardMg [lemma, in fingroup]
TI_center_nil [lemma, in nilpotent]
TI_Ohm1 [lemma, in abelian]
TI_pcoreC [lemma, in pgroup]
tnth [definition, in tuple]
tnth_default [lemma, in tuple]
tnth_map [lemma, in tuple]
tnth_ord_tuple [lemma, in tuple]
tnth_behead [lemma, in tuple]
tnth_fgraph [lemma, in finfun]
tnth_nth [lemma, in tuple]
tnth0 [lemma, in tuple]
topred [projection, in ssrbool]
topredE [lemma, in ssrbool]
total [definition, in ssrbool]
TotalAction [section, in action]
TotalAction [definition, in action]
TotalActions [section, in action]
TotalActions.aT [variable, in action]
TotalActions.rT [variable, in action]
TotalActions.to [variable, in action]
TotalAction.aT [variable, in action]
TotalAction.rT [variable, in action]
TotalAction.to [variable, in action]
TotalAction.toM [variable, in action]
TotalAction.to1 [variable, in action]
tperm [definition, in perm]
tpermC [lemma, in perm]
tpermD [lemma, in perm]
TpermFirst [constructor, in perm]
tpermJ [lemma, in perm]
tpermK [lemma, in perm]
tpermKg [lemma, in perm]
tpermL [lemma, in perm]
TpermNone [constructor, in perm]
tpermP [lemma, in perm]
tpermR [lemma, in perm]
TpermSecond [constructor, in perm]
tpermV [lemma, in perm]
tperm_spec [inductive, in perm]
tperm_proof [lemma, in perm]
tperm_mx [definition, in matrix]
tperm1 [lemma, in perm]
tperm2 [lemma, in perm]
trace_map_mx [lemma, in matrix]
trace_mx11 [lemma, in matrix]
traject [definition, in path]
Trajectory [section, in path]
Trajectory.f [variable, in path]
Trajectory.T [variable, in path]
trajectP [lemma, in path]
trajectS [lemma, in path]
trajectSr [lemma, in path]
traject_iteri [lemma, in path]
transfer [definition, in finmodule]
Transfer [section, in finmodule]
TransferEqType [section, in eqtype]
TransferEqType.eT [variable, in eqtype]
TransferEqType.f [variable, in eqtype]
TransferEqType.T [variable, in eqtype]
TransferFinType [section, in fintype]
TransferFinType.eT [variable, in fintype]
TransferFinType.f [variable, in fintype]
TransferFinType.fT [variable, in fintype]
transferM [lemma, in finmodule]
transfer_morph_subproof [lemma, in finmodule]
transfer_morphism [definition, in finmodule]
transfer_pcycle_def [lemma, in finmodule]
transfer_indep [lemma, in finmodule]
Transfer.abelA [variable, in finmodule]
Transfer.alpha [variable, in finmodule]
Transfer.aT [variable, in finmodule]
Transfer.FactorTransfer [section, in finmodule]
Transfer.FactorTransfer.g [variable, in finmodule]
Transfer.FactorTransfer.Gg [variable, in finmodule]
Transfer.FactorTransfer.trX [variable, in finmodule]
Transfer.FactorTransfer.X [variable, in finmodule]
Transfer.G [variable, in finmodule]
Transfer.gT [variable, in finmodule]
Transfer.H [variable, in finmodule]
Transfer.sHG [variable, in finmodule]
transitive [definition, in ssrbool]
transRs_rcosets [lemma, in action]
trans_subnorm_fixP [lemma, in action]
trans_prim_astab [lemma, in primitive_action]
trivGfun [definition, in gfunctor]
trivGfun_cont [lemma, in gfunctor]
trivGfun_pgFun [definition, in gfunctor]
trivGfun_gFun [definition, in gfunctor]
trivGfun_igFun [definition, in gfunctor]
trivGP [lemma, in fingroup]
trivgP [lemma, in fingroup]
trivgPn [lemma, in fingroup]
trivgVpdiv [lemma, in pgroup]
trivg_center_pgroup [lemma, in sylow]
trivg_Phi [lemma, in maximal]
trivg_Mho [lemma, in abelian]
trivg_card_le1 [lemma, in fingroup]
trivg_card1 [lemma, in fingroup]
trivg_exponent [lemma, in abelian]
trivg_comps [lemma, in jordanholder]
trivg_acomps [lemma, in jordanholder]
trivg_Fitting [lemma, in maximal]
trivg_pcore_quotient [lemma, in pgroup]
trivg_quotient [lemma, in quotient]
trivg_rowg [lemma, in mxabelem]
trivg0 [lemma, in gproduct]
TrivialMxsum [constructor, in mxalgebra]
TrivialSumv [constructor, in vector]
trivial_isog [lemma, in morphism]
trivial_Alt_2 [lemma, in alt]
trivial_mxsum [definition, in mxalgebra]
trivial_addv [definition, in vector]
trivIimset [lemma, in finset]
trivIset [definition, in finset]
trivIsetI [lemma, in finset]
trivIsetP [lemma, in finset]
trivIsetU1 [lemma, in finset]
trivm [definition, in morphism]
trivMg [lemma, in fingroup]
TrivMorphism [section, in morphism]
TrivMorphism.aT [variable, in morphism]
TrivMorphism.rT [variable, in morphism]
trivm_morphM [lemma, in morphism]
triv_morph [definition, in morphism]
triv_cprod [lemma, in gproduct]
triv_restr_perm [lemma, in action]
trmx [definition, in matrix]
trmxK [lemma, in matrix]
trmxV [lemma, in matrix]
trmx_cast [lemma, in matrix]
trmx_dlsub [lemma, in matrix]
trmx_delta [lemma, in matrix]
trmx_mul_rev [lemma, in matrix]
trmx_mul [lemma, in matrix]
trmx_const [lemma, in matrix]
trmx_drsub [lemma, in matrix]
trmx_inv [lemma, in matrix]
trmx_adj [lemma, in matrix]
trmx_inj [lemma, in matrix]
trmx_ulsub [lemma, in matrix]
trmx_usub [lemma, in matrix]
trmx_dsub [lemma, in matrix]
trmx_lsub [lemma, in matrix]
trmx_linear [definition, in matrix]
trmx_additive [definition, in matrix]
trmx_rsub [lemma, in matrix]
trmx_ursub [lemma, in matrix]
trmx0 [lemma, in matrix]
trmx1 [lemma, in matrix]
True [abbreviation, in mxrepresentation]
tr_pid_mx [lemma, in matrix]
tr_col_perm [lemma, in matrix]
tr_block_mx [lemma, in matrix]
tr_scalar_mx [lemma, in matrix]
tr_col' [lemma, in matrix]
tr_row [lemma, in matrix]
tr_xrow [lemma, in matrix]
tr_diag_mx [lemma, in matrix]
tr_row' [lemma, in matrix]
tr_col_mx [lemma, in matrix]
tr_row_mx [lemma, in matrix]
tr_xcol [lemma, in matrix]
tr_row_perm [lemma, in matrix]
tr_tperm_mx [lemma, in matrix]
tr_col [lemma, in matrix]
tr_perm_mx [lemma, in matrix]
tsize [definition, in tuple]
tT [abbreviation, in tuple]
Tuple [constructor, in tuple]
tuple [library]
tupleE [lemma, in tuple]
tuple_subFinType [definition, in tuple]
tuple_finType [definition, in tuple]
tuple_finMixin [definition, in tuple]
tuple_subCountType [definition, in tuple]
tuple_countType [definition, in tuple]
tuple_choiceType [definition, in tuple]
tuple_predType [definition, in tuple]
tuple_eqType [definition, in tuple]
tuple_subType [definition, in tuple]
tuple_choiceMixin [definition, in tuple]
tuple_eqMixin [definition, in tuple]
tuple_eta [lemma, in tuple]
tuple_countMixin [definition, in tuple]
tuple_map_ord [lemma, in tuple]
tuple_of_ev [definition, in vector]
tuple_of [record, in tuple]
tuple_of_evK [lemma, in vector]
tuple0 [lemma, in tuple]
Tuple1spec [constructor, in tuple]
tuple1_spec [inductive, in tuple]
tval [projection, in tuple]
T' [abbreviation, in alt]
