Global Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (14626 entries)
Projection Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (165 entries)
Record Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (112 entries)
Lemma Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (7292 entries)
Section Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (761 entries)
Constructor Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (250 entries)
Abbreviation Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (390 entries)
Inductive Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (84 entries)
Definition Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (3144 entries)
Module Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (126 entries)
Axiom Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (28 entries)
Variable Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (2221 entries)
Library Index A B C D E F G H I J K L M N O P Q R S T U V W X Y Z _ other (53 entries)
N (lemma)
nandP [in ssrbool]
nary_congruence [in ssreflect]
nary_mxsum_proof [in mxalgebra]
nary_addv_proof [in vector]
natnseq0P [in seq]
natr_negZp [in zmodp]
natr_Zp [in zmodp]
NatTrec.addE [in ssrnat]
NatTrec.add_mulE [in ssrnat]
NatTrec.doubleE [in ssrnat]
NatTrec.expE [in ssrnat]
NatTrec.mulE [in ssrnat]
NatTrec.mul_expE [in ssrnat]
NatTrec.oddE [in ssrnat]
nat_of_add_bin [in ssrnat]
nat_irrelevance [in ssrnat]
nat_power_theory [in ssrnat]
nat_of_succ_gt0 [in ssrnat]
nat_negb [in fintype]
nat_Cauchy [in ssrnat]
nat_semi_ring [in ssrnat]
nat_of_exp_bin [in ssrnat]
nat_AGM2 [in ssrnat]
nat_of_addn_gt0 [in ssrnat]
nat_pickleK [in choice]
nat_of_binK [in ssrnat]
nat_of_mul_bin [in ssrnat]
nat_semi_morph [in ssrnat]
nconsK [in seq]
ncprodS [in center]
ncprod0 [in center]
ncprod1 [in center]
ncycles_mul_tperm [in perm]
nderivnC [in poly]
nderivnD [in poly]
nderivnMn [in poly]
nderivnMNn [in poly]
nderivnN [in poly]
nderivnXn [in poly]
nderivnZ [in poly]
nderivn_poly0 [in poly]
nderivn_amulX [in poly]
nderivn_def [in poly]
nderivn_linear_proof [in poly]
nderivn_map [in poly]
nderivn0 [in poly]
nderivn1 [in poly]
nderiv_taylor [in poly]
nderiv_taylor_wide [in poly]
negbF [in ssrbool]
negbFE [in ssrbool]
negbK [in ssrbool]
negbLR [in ssrbool]
negbNE [in ssrbool]
negbRL [in ssrbool]
negbT [in ssrbool]
negbTE [in ssrbool]
negb_eqb [in eqtype]
negb_exists_in [in fintype]
negb_forall [in fintype]
negb_inj [in ssrbool]
negb_add [in eqtype]
negb_exists [in fintype]
negb_and [in ssrbool]
negb_forall_in [in fintype]
negb_or [in ssrbool]
negb_imply [in ssrbool]
negnK [in prime]
negP [in ssrbool]
negPf [in ssrbool]
negPn [in ssrbool]
nElemI [in abelian]
nElemP [in abelian]
nElemS [in abelian]
nElem0 [in abelian]
nElem1P [in abelian]
neq_lift [in fintype]
neq_bump [in fintype]
neq_ltn [in ssrnat]
neq0_lt0n [in ssrnat]
next_rev [in path]
next_prev [in path]
next_rot [in path]
next_cycle [in path]
next_nth [in path]
next_rotr [in path]
next_map [in path]
nilP [in seq]
nilpotentS [in nilpotent]
nilpotent_proper_norm [in nilpotent]
nilpotent_maxp_normal [in sylow]
nilpotent_class [in nilpotent]
nilpotent_Hall_pcore [in sylow]
nilpotent_sol [in nilpotent]
nilpotent_Fitting [in maximal]
nilpotent_sub_norm [in nilpotent]
nilpotent_pcore_Hall [in sylow]
nilpotent_pcoreC [in sylow]
nilpotent_subnormal [in nilpotent]
nilpotent1 [in nilpotent]
nil_class_injm [in nilpotent]
nil_class_quotient_center [in nilpotent]
nil_comm_properl [in nilpotent]
nil_class_ucn [in nilpotent]
nil_Zgroup_cyclic [in sylow]
nil_class_morphim [in nilpotent]
nil_class0 [in nilpotent]
nil_comm_properr [in nilpotent]
nil_class2 [in sylow]
nil_class1 [in nilpotent]
nil_class3 [in sylow]
nil_class_pgroup [in sylow]
nonconform_mx [in matrix]
nontrivial_gacent_pgroup [in sylow]
nonzero_poly1 [in poly]
normalG [in fingroup]
normalGI [in fingroup]
normalGY [in fingroup]
normalI [in fingroup]
normalJ [in fingroup]
normalM [in fingroup]
normalP [in fingroup]
normalS [in fingroup]
normalSG [in fingroup]
normalYG [in fingroup]
normal_subnorm [in fingroup]
normal_norm [in fingroup]
normal_sub_max_pgroup [in pgroup]
normal_rfix_mx_module [in mxrepresentation]
normal_sylowP [in sylow]
normal_refl [in fingroup]
normal_rank1_structure [in extremal]
normal_Hall_pcore [in pgroup]
normal_max_pgroup_Hall [in pgroup]
normal_cosetpre [in quotient]
normal_subnormal [in gseries]
normal_sub [in fingroup]
normal_pgroup [in sylow]
normal1 [in fingroup]
normC [in fingroup]
normCs [in fingroup]
normD1 [in fingroup]
normG [in fingroup]
normJ [in fingroup]
normP [in fingroup]
normsD [in fingroup]
normsG [in fingroup]
normsGI [in fingroup]
normsI [in fingroup]
normsIG [in fingroup]
normsIs [in fingroup]
normsM [in fingroup]
normsP [in fingroup]
normsR [in fingroup]
normsRl [in commutator]
normsRr [in commutator]
normsU [in fingroup]
normsY [in fingroup]
norms_norm [in fingroup]
norms_bigcap [in fingroup]
norms_class_support [in fingroup]
norms_gen [in fingroup]
norms_cent [in fingroup]
norms_bigcup [in fingroup]
norms_cycle [in fingroup]
norms1 [in fingroup]
norm_sub_rstabs_rfix_mx [in mxrepresentation]
norm_sub_max_pgroup [in pgroup]
norm_joinEr [in fingroup]
norm_normalI [in fingroup]
norm_conj_norm [in fingroup]
norm_conj_cent [in hall]
norm_joinEl [in fingroup]
norm_conj_autE [in automorphism]
norm_gen [in fingroup]
norm_rlcoset [in fingroup]
norm1 [in fingroup]
norP [in ssrbool]
not_isog_Dn_DnQ [in extraspecial]
not_false_is_true [in ssrbool]
not_simple_Alt_4 [in alt]
not_locked_false_eq_true [in ssreflect]
nseq_tupleP [in tuple]
nthP [in seq]
nth_set_nth [in seq]
nth_behead [in seq]
nth_fgraph_ord [in finfun]
nth_map [in seq]
nth_take [in seq]
nth_mkseq [in seq]
nth_traject [in path]
nth_last [in seq]
nth_rev [in seq]
nth_nseq [in seq]
nth_enum_ord [in fintype]
nth_iota [in seq]
nth_cat [in seq]
nth_default [in seq]
nth_find [in seq]
nth_rcons [in seq]
nth_scanl [in seq]
nth_enum_rank [in fintype]
nth_zip [in seq]
nth_pairmap [in seq]
nth_drop [in seq]
nth_uniq [in seq]
nth_index [in seq]
nth_incr_nth [in seq]
nth_zip_cond [in seq]
nth_ncons [in seq]
nth_nil [in seq]
nth_enum_rank_in [in fintype]
nth_ord_enum [in fintype]
nth0 [in seq]
ntransitive_primitive [in primitive_action]
ntransitive_weak [in primitive_action]
ntransitive0 [in primitive_action]
ntransitive1 [in primitive_action]
nt_prime_order [in cyclic]
nt_pnElem [in abelian]
nt_gen_prime [in cyclic]
nz_row_eq0 [in matrix]
nz_row_mxsimple [in mxrepresentation]
nz_row_sub [in mxalgebra]
nz_socle [in mxrepresentation]
n_compC [in fingraph]
n_comp_closure2 [in fingraph]
n_act_dtuple [in primitive_action]
n_act_add [in primitive_action]
n_act0 [in primitive_action]
n_act_is_action [in primitive_action]
n_comp_connect [in fingraph]
